View Full Version : Coil 'polatity'
curt
09-10-2006, 10:21 AM
On a 12 negative ground system, the coil + goes to the distributor? Would it be opposite for a positive ground system?
Alan
09-10-2006, 10:40 AM
And all these years I have been doing it the other way.
N8N
09-10-2006, 10:48 AM
no, on a normal car, the coil + is the feed from the ballast resistor. The coil - goes to the points.
Now to answer your question, I would ASSume that this would be reversed for a +ive ground car, but I don't honestly know for sure.
curt
09-10-2006, 03:05 PM
Normal car = positive ground car?
curt
09-10-2006, 03:11 PM
I had TWO Questions . Does negative ground mean, + from coil to distributor. Then does positive ground mean, - from coil to distributor? Are those questions correct or backwards???
Alan
Pos. ground, you have got it right.
Alan
09-10-2006, 03:13 PM
OK curt lets start over. Pos. ground + to dist. Neg . ground - to dist.
Pat Skelly
09-10-2006, 07:11 PM
The points are the grounding path for the primary circuit.
The current flow is toward ground, which is through the points.
The act of opening the points interupts the normal flow of the primary circuit. The primary wire from the coil to the distributor should be the NEG side of the coil.
Pat Skelly
62 GT Hawk
53 Studillac
37 Dictator Coupe
09-10-2006, 08:19 PM
What Alan said.... the last time.;)
