I have two jacks that I have no idea what studebaker models they are from. One is a tripod (red in color) It has a silver button cap where the crank handle pivits. The handle has a wooden cylinder. The three legs are round with the side cut out to creat a channel. The center one has the screw down the middle. The base is Black iron with the lazy S embossed (it pivots) The other two legs have small red feet that also pivot. There is a thick silver chain that conects all three. The hook on the screw is thick black iron and also has the Lazy S embossed in it.
the second jack seems older. It is red as well. It has no cap on top. The top of the crank has a round wooden ball with a flat top. The center leg is rounded with the screw don the midle. the hook on it is small black iron. The two outer legs are V shaped . The bottom feet are square and do not pivot they are welded on. the Lazy S in the center foot is a decal (red. white and blue) almost delapedated. The chain is similar to a swing chain that connects all three.
Can someone shed some light.
I have a 57 silver hawk. and have no jack. Is one of these right? doesn't fit in the spot in trunk.
I paid alot for these jacks grabbing them quickly so as not to loose the opportunity in case one would fit my car. If its not right I will sell them.
