View Full Version : Synchronizer question
lstude
06-14-2007, 09:00 PM
I know the 3rd. gear synchronizer is bad in the 63 Lark overdrive transmission in my 52 Commander, but lately I can't get it into [u]any</u> gear. I adjusted the clutch and that helped, but later it did it again. I took it out of OD and then I could get it into gear, but later it happened again and once again I came back later and it went in gear just fine.
What is going on here?
Leonard Shepherd
http://leonardshepherd.com/
http://i129.photobucket.com/albums/p235/lstude1/Mein64DaytonaatBradfieldssm2.jpghttp://i129.photobucket.com/albums/p235/lstude1/AlmostreadyforSB6-4.jpg
N8N
06-14-2007, 09:36 PM
If I had to hazard a guess, I'd think you have an issue with the clutch linkage. The clutch linkage for the late, suspended-pedal cars is... well... what's the word I'm looking for? Crap. Yes, that's it. Usual culprit is severe wear/bending of the pushrod, although a close second would be rotation of the "ear" on the little cross-linkage thing. Fix is to take a known-good one to use as a pattern, rotate the ear back where it's supposed to be, and weld it in place. For the pushrod, you could make one out of some clevises and grade-5 or grade-8 all thread, although that will make adjustment more difficult (have to drop one end to lengthen/shorten linkage)
lstude
06-14-2007, 09:43 PM
The car has the 63 tranny but uses the floor pedal of the 52. Would that set-up be causing the problem, and why would it work sometimes and not another?
Leonard Shepherd
N8N
06-14-2007, 09:49 PM
hmmm.... that's different then. I'm not familiar with really anything pre-53 so I can't say whether that could be your problem or not. But if you do have the rotating linkage between the pedal and a socket mounted to the trans or bellhousing, I would check and see if that ear is rotating on the splines. It does kind of sound like your clutch adjustment is tightening up as you drive.
wayne
06-14-2007, 10:21 PM
From my understanding The shaft that goes from the clutch pedal to the clutch can slip. I have not had this problem with my 51 but was told if I do to weld it.
mbstude
06-15-2007, 08:13 AM
quote:From my understanding The shaft that goes from the clutch pedal to the clutch can slip. I have not had this problem with my 51 but was told if I do to weld it.
Yepp, that's true. My grandad welded the shaft in my uncle's '51 several years ago, and we've never had any trouble since. :)
Matthew Burnette
'59 Scotsman
'63 Daytona
Hazlehurst, GA
http://i81.photobucket.com/albums/j209/mbstude/save_sasco_sig.jpg
dictator27
06-15-2007, 07:59 PM
If one of the facings comes off of the clutch disc, this can give you an intermitent no shift problem.
Terry
lstude
06-15-2007, 08:33 PM
I AM EMBARRASSED TO SAY THIS BUT THE REAR SEAL HAS BEEN LEAKING AND I CHECKED THE FLUID AND I CAN'T FIND ANY! [:0]
Leonard Shepherd
mbstude
06-15-2007, 08:50 PM
Good thing you caught that, Leonard! Fill it up and make sure it all still works. :)
Matthew Burnette
'59 Scotsman
'63 Daytona
Hazlehurst, GA
