63 Champ Turn Signal Fuse
  • Electrical: 63 Champ Turn Signal Fuse
    Where is the fuse controlling the signal (turn) lights? The manual states that a 14-amp fuse controls this; the flasher wires disappear into a harness going through the firewall. Turn signals are dead; other lights are fine. Any help?
    The 14 Amp. turn Sig. fuse is on the small piece of insulator board on the left, under the dash. It is with the Stoplight/Dome light Fuse and the Flasher Unit, that should be easy to see.
      Turn Signal Fuse
      Thanks, Studerich, I'll look again, guess I missed it earlier
        Not sure if its the same in the trucks, but probably.
          I think the flasher and fuses might have been relocated on the 8E Champs due to the bracketry for the suspended pedals. I don't know where they moved to though. I'm not aware of a revised wiring diagram for the 8E models either.
          Restorations by Skip Towne
