Well, I am STILL having problems with the '61 Cruiser running rough at low speeds-hesitating, surging, skipping and sorta sputtering, and wanting to stall out on stops unless I keep one foot on a gas a bit and one on the brake, which is sort of an aggravation with an automatic car. It does this as speeds that are below 40 m.p.h and gets worse the slower I drive. It stops doing this, though, as soon as I put the car in park or neutral-only does it in a motion gear. It makes no difference if the AC is on or not. It also stops doing it once I reach speeds over 40, and the faster I drive, the smoother it runs. I've done just about everything I can think of-replaced the softer rubber fuel lines with stronger, new lines, replaced the fuel filter, had the carb totally re-built with a Stude carb rebuild kit, by-passed and replaced the old original fuel pump(which was only putting out an inconsistent 1-3 pounds of pressure)with a new electric fuel pump, cleaned the points, completely cleaned and bored out the radiator and run in fresh antifreeze and temp reducer and replaced the old four-blade fan with a six-blade flex fan. The car is no longer running hot, not even in town in OUR weather(which was near 100 this past week)with the AC running full blast, and this problem occurs whether I've been driving it for half an hour or two minutes, before the engine even has time to heat up, so I don't think that vapor lock is the problem, especially not with the new fuel lines. It's also still "running on" a bit after I switch the ignition off, though not as bad as it did before the carb was rebuilt. Is all this possibly the result of modern gasolines, or just using regular unleaded? Will switching to a premium-grade gas help, or what about adding that lead substitute? Or, am I maybe thinking along the wrong lines by simply assuming it's something fuel or fuel system related? I wouldn't THINK that a faulty or worn-out generator would cause this, but then, I've never driven a car that had a generator as opposed to an alternator, so I could be wrong. Any suggestions as to what this could be, and how to stop it, would be greatly appreciated. It DOES idle very low when I put it in drive, then revs back up when I put in it park, though the idle has been adjusted several times.
pitbulllady
pitbulllady
