Were there ever multiple carbs offered on a factory Studebaker engine. I'm aware that the '56 Golden HawK, powered by a 2x4 equipped Packard engine, met that criteria, but it wasn't a Studebaker engine. The one in question is the '64, 304 with 335 HP. Believe that was the R3. I assumed it was supercharged, but somewhere I read it had two fours. Have never read about others.
Multiple Carbs
The R4 was Dual AFB 4 Brl. 290 H.P. unsupercharged, overcarburated ...basically a dog.
It did have R3/R4 Heads, ForgedTrue Pistons, high lift, more overlap Cam than R1/R2 etc. like the R3, but higher Compression.StudeRich
The R4 was the only engine offered with dual 4 bbl. carbs. The dual quad equipped Packard engines were never offered on the '56 Golden Hawk. There was a performance option called the Jet Streak kit which used the Packard Caribbean dual quad intake setup, a dual point distributor and a performance cam and valve train setup. The Jet Streak kit was released for production and even mentioned in some magazine articles but was never actually produced.
Think of the R4 as an R3 but with dual AFBs instead of the blower setup, and with 12:1 compression (from domed pistons) instead of the R3's 9.75:1 ratio. And (offically) only 290 hp vs 335 hp for the R3.Last edited by R2Andrea; 11-05-2011, 06:27 PM.R2Andrea
Do you have a uni-syn tool?
Almost a must for setting up multiple carbs...
I have one if you would like to borrow it.
JeffHTIH (Hope The Info Helps)
I've had a Uni-Syn for years. Bought it first for use on motorcycles, (JC Waitawhile in the late 50s) but can't remember the last flathead V8 with only one carb. that I've had.
Klif55 Speedster/Street Machine
63 Avanti R2
64 Convertible R1
R2Andy, thanks for the clarification. I knew Packard's '55, 352 was rated both @ 260 & 275. Then in '56 the only 352 offered was rated at 275. I didn't realize Packard tweaked the single 4bbl engine to 275, instead I assumed the Studes got leftover '55s which were 2x4 352s. Guess that's what happens when assumptions are made, I just didn't have that information. Is it correct that the R2 was a slightly hor-roded 225hp 289? What comprised the changes, a little better hyd. cam and higher comp. ratio? Any other changes?
Thanks,
CarCrosswordDan
Flat top pistons, hotter cam,9 to 1 compression ratio,supercharger. No "Studebaker" built engine ever used hydraulic lifters. Only hydraulics were in Packard and McKinnon GM engines used.
Originally posted by CarCrosswordDan View PostR2Andy, thanks for the clarification. I knew Packard's '55, 352 was rated both @ 260 & 275. Then in '56 the only 352 offered was rated at 275. I didn't realize Packard tweaked the single 4bbl engine to 275, instead I assumed the Studes got leftover '55s which were 2x4 352s. Guess that's what happens when assumptions are made, I just didn't have that information. Is it correct that the R2 was a slightly hor-roded 225hp 289? What comprised the changes, a little better hyd. cam and higher comp. ratio? Any other changes?
Thanks,
CarCrosswordDanFrank van Doorn
Omaha, Ne.
1962 GT Hawk 289 4 speed
FWIW, to try to compete with the 275hp Packard-engined '56GH, Studebaker rated the '57GH Studebaker 289" at 275hp with a 2bbl carb, standard cam and 7.5 c.r. Then, the '63-64 R2 with a 4bbl, hotter cam and 9:1 c.r. was rated at 289hp. Which one do you believe?
jack vinesPackardV8
But Jack, wasn't the '57 equipped with a Paxton supercharger?
jack vinesPackardV8
The R-4 engine was rated at 280BHP not 290.....my father owned a '56 GH and indeed it had dual quads....also the the biggest engine that Packard offered in '56 was a 374 CID engine rated at 290 BHP with single quad carb.Originally posted by R2Andy View PostThe R4 was the only engine offered with dual 4 bbl. carbs. The dual quad equipped Packard engines were never offered on the '56 Golden Hawk. There was a performance option called the Jet Streak kit which used the Packard Caribbean dual quad intake setup, a dual point distributor and a performance cam and valve train setup. The Jet Streak kit was released for production and even mentioned in some magazine articles but was never actually produced.
The R series engines were offically rated as follows: R1 - 240 hp, R2 - 289 hp, R3 - 335 hp and the R4 - 290 hp. These are the figures released by Studebaker. Your fathers 56J may have had dual quads on it, but it left the assembly line equipped with a 352 and single 4 bbl carb. The 374 was only built in 1956 and had dual quads. It came in the Caribbean and IIRC, the 400.R2Andrea
