I have a one wire internal regulated alt. I'm going to put on the Lark since it was give to me. I also plan to run Pertonix. Do I have to run a Voltage Resistor or a Ballast Resistor anymore?
Can I ditch the Voltage Regulator?
Tags: None
You said voltage "regulator" in your heading and are talking about resistors. If you do mean voltage regulator, you can dispose of the external regulator and tape off the leads. If you mean a ballast resistor, I'm not sure of the answer...the ballast resistor is matched to the coil. If you have a Pertronix with a Pertronix coil, they're probably already matched, but maybe contacting Pertronix is the best thing to do.Poet...Mystic...Soldier of Fortune. As always...self-absorbed, adversarial, cocky and in general a malcontent.
Originally posted by JDC View PostI was actually asking about booth. I'm putting a new harness in so I just wondered if I needed the voltage regulator. Ballast Resister just popped in my head while I was typing.Poet...Mystic...Soldier of Fortune. As always...self-absorbed, adversarial, cocky and in general a malcontent.
A three wire alternator is a much better choice for a car. It's a little more trouble to wire, but not that much more trouble. It will be voltage sensing which will make your lights brighter, and it will have an internal voltage regulator. It's also a lot easier to find a replacment if it wears out--the 10 SI alternator is the 3-wire alternator most people put on a car. The 10-SI a Delco, and time-proven reliable. You can find a replacement in any auto parts store in the Country, which you can't say about a 1-wire. There's a reason why somebody gave that one-wire alt. to you.1953 Chev. 210 Convertible, 261 6cyl w/Offy dual intake (But I always did love Studebakers!)
1995 Dodge/Cummins Pickup, 250 HP, 620 Ft. Lbs. of Torque, ATS trans.
Robert Rausch
A three wire alternator is a much better choice for a car. It's a little more trouble to wire, but not that much more trouble. It will be voltage sensing which will make your lights brighter, and it will have an internal voltage regulator. It's also a lot easier to find a replacment if it wears out--the 10 SI alternator is the 3-wire alternator most people put on a car. The 10-SI a Delco, and time-proven reliable. You can find a replacement in any auto parts store in the Country, which you can't say about a 1-wire. There's a reason why somebody gave that one-wire alt. to you.The only difference between death and taxes is that death does not grow worse every time Congress convenes. - Will Rogers
My Lark with its 350 Chevy has a 1974 GM alternator. I ran a direct 8 gauge wire to the Batt side of the starter relay; a jumper between the #2 (small) terminal and the Batt terminal on the alternator and a wire from the Gen light to the #1 terminal.--------------------------------------
