I am reassembling my Dana 44 after changing seals and a bearing cup. I now realize that I forgot to mark the companion flange to show which splines on the pinon shaft it was lined up to. What am I risking by just putting it back together?
Companion flange to pinion shaft witness mark. What if I forgot?
Rear Axle: Companion flange to pinion shaft witness mark. What if I forgot?
Rob in ND
\'53 Commander resto-mod (work in process)Tags: None
'Shouldn't make any difference how you put it back together. Just make sure there isn't a flat or other provision to orient the shaft to the flange in certain way; 'shouldn't be. BPWe've got to quit saying, "How stupid can you be?" Too many people are taking it as a challenge.
Tapered roller bearing components definitely do 'wear in' together, and become comfortable.
Proper bearing maintenance should be to keep like components together, and replace them in sets.
It will accellerate the wear process to mix a new cone with an old cup.
If you read the info that SKF or Timken, or Koyo, or MRC... They will always say the same thing.
Originally posted by ROADRACELARK View PostJust a thought.....why wouldn't one change the roller bearing along with the cup?? Wouldn't a "worn" cup also result in "worn rollers"?? I thought you never replaced one without the other.?.?. then what do I know.
Dan Miller
Auburn, GAHTIH (Hope The Info Helps)
The bearing cup I changed out was for one of the carrier bearings. The roller bearing showed no sign of any wear or any damage that I could see. The cup didn't show wear either. That is to say there was no ridge or groove, or hammering. However, the cup had a few tiny flakes spalled off of it. The other carrier bearing roller and cup look great. The pinion bearing and cup looked great.
Car has 62,000 miles and has sat for the last 50 years. Also cleaned everything as best I could.
The Manual warns us to never clean the inside of the case.
Since you have done that, just be very careful that there are no remains of Solvent, Kerosene etc. in the case and it is throughly dry.
I doubt that they had the highly evaporative products like Brake Clean that we have today, so residue that would thin the Oil was their concern.StudeRich
