View Full Version : 2R Column Upper Shift Lever "floats"
dan0
06-11-2007, 06:51 PM
All-
Should the upper link on a column shifter (2R11 Commander 6 T-86) be free to rotate on the shaft?
Seems like it should be affixed to something; welded, pinned...etc
dan0
Herd:
06 Jetta TDI
1941 M15
1953 2R11
2001 F-350
1989 Caprice
Deere's:
67' 112H
88' 332
06-11-2007, 08:56 PM
You're talking about the cast metal thingy just under the steering wheel? It has a big screw that tightens and causes the part to clench onto the top of the steering column tube. If that's what you're talking about, find the head of that screw (it's inset into it's hole) and tighting it good. That should stop it from flopping around.;)
Miscreant adrift in
the BerStuda Triangle
