I purchased a 1956 Sky Hawk this summer and now that the car show season is over am fixing some of the nit noid stuff under the hood. I am currently working on the generator. I removed it and the related mounting hardware and striped and painted everything. When I removed the generator I found there was a (I think) ground wire mounted to the case of the generator, however the other end was not attached to anything. Is that wire suppose to be mounted to the inner fender? It is clearly the only place it would reach. Else, maybe I should just remove it and throw it away?
Regards,
Jerry Johnson
Regards,
Jerry Johnson
