My '57 Hawk seems too have a "weak" detent or lock in the Park position. I believe the transmission is the Flightomatic. The Shop Manual suggests three things could be wrong:
My questions in order as above:
- Manual [shift] linkage misadjusted
- Damaged internal linkage
- Damaged PARK pawl
- Is there a written procedure for adjusting the shift linkage on the Flightomatic (as with the Ultramatic)?
- Is there a quick way to determine internal linkage damage with the pan on?
- Is there an easy procedure for replacing the PARK pawl?
Thank you once again in advance.
