by chance no one would happen to have a float for a wcfb carb?
carter wcfb
It's a good and legit question.
Brass floats can spring a leak and fill with gas and sink...
They can also be crushed by raised atmospheric air pressure.
Phenolic floats can have the coating abrade away and soak up gas and sink.
Good to be curious, as you are...
quote:Originally posted by hotwheels63r2
How does a float go bad, I have never had that problem... I could picture the tab breaking? or does the solder fail? Curious, not trying to pick at the post....
MIKEHTIH (Hope The Info Helps)
