I am an Avanti new comer. My father in law gave his original owner 63 Avanti after 35 years of seeing it in his garage in LA. I have finished total restoration of the Avanti (R4252A), almost. The car sat in LA for 6+ years and my mechanic has it running beautifully except for a transmission problem. He drained the transmission, replaced seals and filled with new fluid. It also has new motor mounts.
The 3 speed Borg Warner auto transmission will not shift into 3rd gear. It is smooth and quiet into reverse, neutral, 1sst and 2nd but won't shift up. I think the torque converter is missing a tooth or two. It starts instantly but has clunk when the starter turns over.
So am I looking at a complete overhaul of the tranny or can a transmission expert go in and do micro surgery to find and fix the problem? The torque converter plate would be replaced in the process.
OR should I consider a replacement Ford FMX or newer transmission?
Thoughts from Avanti or Studebaker pros will be most welcome.
Thanks, Legs
Thanks
Thanks, Legs
Thanks
