View Full Version : Help with 53 Starliner
Gary1953
06-09-2007, 08:43 PM
http://i98.photobucket.com/albums/l269/gsandes50/53fuleline.gif
I am having trouble with my 1953 Commander Starliner. I think it is a fuel line problem The picture above is the line between the fuel pump and the carb. At one of the bends the curve of the line is not as wide as the rest of the fuel line. Could this cause my car to cut out like it is starving fuel to the point it will stop running?
Leading to vapor lock?
Any help will be appreciated.
http://i98.photobucket.com/albums/l269/gsandes50/1953Stude.jpg
Gary Sanders
Nixa, MO
wagone
06-09-2007, 08:54 PM
It does appear to be pinched rather tight. Why not cut the bend out and replace with a piece of rubber fuel hose as a test? Steel gas line is cheap to replace (unless originality is an issue--and even then) and if that is the cause it needs to be replaced anyway. Just my two cents.........
wagone and the R2 Avanti
Gary1953
06-09-2007, 10:09 PM
Wagone,
The more I look at the bend I agree it is to tight and I think it is restricting gas flow. I'm going to put a rubber hose in line tomorrow and see how it does.
Gary Sanders
Nixa, MO
52 Ragtop
06-09-2007, 10:49 PM
Might try a new steel line, and get a 90 degree fitting so the steel line does not need to bend in a U!
Jim
rrausch
06-09-2007, 11:42 PM
A fellow can also buy a tubing bender at most auto parts stores for a few bucks. I have one, and it allows you to bend tubing quite easily without kinking it.
1953 Chev. 210 Convertible, 261 6cyl w/Offy dual intake (But I always did love Studebakers!)
1995 Dodge/Cummins Pickup, 250 HP, 620 Ft. Lbs. of Torque, ATS trans.
gordr
06-10-2007, 12:28 AM
Those kinks are unsightly, but I doubt they are causing your problem. Think for a moment, how big is the inlet jet where the float needle seats? Probably well under 1/8", unless you have some kind of super high performance carb on there. There's the real bottleneck in the fuel line, and it's intended to be there. Do you really think those kinks are so tight as bring the interior of the line down to less capacity than the carb float valve?
First step: under what conditions does the apparent fuel starvation occur? Engine cold or hot, idling or under load? After a hot shutdown? The circumstances will give you a clue. Vapor lock will normally only happen with a hot engine on a warm or hot day. Carburetor ice can occur if it's a humid day in the 30s F.
A weak fuel pump is a possible cause; so is dirt in the fuel line, or in the valves of the fuel pump, or in the float needle and seat assembly. Since that's the real choke point, flaky or fibrous debris tends to lodge there.
Another potential problem is a pinhole leak in the suction line from the fuel pump back to the tank. This can allow the fuel pump to suck air, and really mimics vapor lock.
Even something like a leaf, dead bug, or scrap of paper floating around in the tank can occasionally block the pickup tube. Studes didn't use a filter sock on the fuel pickup tube like they have on modern cars, so they can be shut down by stray debris in the tank.
Hope this helps. Post back with more details about the circumstances surrounding these stalling episodes.
N8N
06-10-2007, 03:37 PM
Ah yes, but a GOOD tubing bender is hard to find :) I like my "Imperial" brand benders, but I have no idea where to find them new. I have bought mine all used off eBay or at yard sales.
True story, my grandfather used to be a tube fitter in a factory, and he was the guy that showed me how to bend and flare tube. (occasional brake repairs etc.) When he passed away my grandmother asked me if there were any tools I wanted and I asked about his tubing tools, apparently he'd sold them to a neighbor because he figured since I went to college and got a good desk job that I wouldn't have any use for them :(
06-10-2007, 03:59 PM
Try these Ezibend tubes...
http://www.brakequip.com/tubes.html
No tubing bender needed. Pretty nifty!
NAPA here stocks them in various lengths.
