I am working on the steering on my 53 Commander. I have a few questions.
1. How many balls are supposed to be in the Ross box? I think it had 11 in the top and 11 in the bottom. But, there seems to be room for 12 in each end. When I ordered new ones from SI, I got 25.
2. There were 2 small foam spacers or plugs that came out of the center of the steering column. It seems their function is to center and protect the horn wire. When I put them back in, where are they to be located along the column? Bottom, center, or top?
3. Is the center bell crank linkage supposed to be centered when installed? One of my tie rods was set about an inch longer than the other.
4. When I reassemble the Ross box, should I use some RTV on the new gasket or just put it on dry?
I have read many posts on the Ross vs. Saginaw issue. Also read many on the fluid vs. grease issue. Since the Ross box looks like it is very good shape, I opted to restore it and see how it performs. I put a new output shaft seal in it and am using John Deere Special-Purpose Corn Head Gun Grease - AN102562 in it. It is the thinnest grease I have ever seen, thicker than gear lube, but barely. $4 at local JD dealer.
