Note I'm still repowering my 1962 Lark with a belly button motor (350 Chevy) so finishing up the disc brake conversion is later on. That stated; since I already installed a new dual master cylinder for a 1968 Mustang disc brake car application; what booster will work, assuming the pedal effort is too high?
1968 Mustang power disc MC on a 1962 Lark, what booster will work?
I had a 62 ragtop that I used my disc kit on, along with a 68 Mustang M/C, NO power booster. Pedal effort was minimal.
Jim"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
Originally posted by 52 Ragtop View PostI had a 62 ragtop that I used my disc kit on, along with a 68 Mustang M/C, NO power booster. Pedal effort was minimal.
Jim--------------------------------------
My 54 wagon stops very nicely with four wheel disc and "no" booster..
Why waste you money and space when you don't have to.
A 1" piston will activate a normal set of four calipers with the effort that just about anyone but a 2 year old can handle.
Not too hard, not too easy. Easy to modulate/control.
Just what I did in my wagon, and very happy with the results.
If it fits...
Originally posted by 1962larksedan View PostNote I'm still repowering my 1962 Lark with a belly button motor (350 Chevy) so finishing up the disc brake conversion is later on. That stated; since I already installed a new dual master cylinder for a 1968 Mustang disc brake car application; what booster will work, assuming the pedal effort is too high?
I just acquied a '60 Lark which I plan on doing about the same thing with. I don't yet know what is needed to convert the front to disc brakes, but I do know I'll need a proportioning valve and a dual MC. As for the booster you need, go to a Junk yard and start looking at the Ford stuff. They will all pretty much fit the MC you have. It would probably be just as easy to get the whole booster and MC together. The big problem may be size and fit. The Ford Rangers and Explorers have a rather compact booster.
I am curious what you found to convert to disc brakes. I wonder if the same thing applies to my '60 Lark???
In the past I have found that manual disc brakes are not all that much fun.
If you are still looking form something when I get around to that part I'll let you know what I found. I still have the 289 Studebaker V8 which I think may take up more room than your GM 350. If I can find something to fit it, then itb ought to work for you. I have an Explorer booster with an MC on it somewhere if I can find it. If I can I'll make some measurements. I can't help but think there will be some kind of mods to make though.
Later...
Dave
Later...
Dave
Originally posted by 1962larksedan View Postwww.turnerbrake.com/ His kits cover 1951-66 Studes as well as Avantis till ca. 1985; all of the above are kingpin cars.
