I am trying to locate the VIN # on the chassy on a 1941 commander. I am having a Highway patrol officer verify the vehicle friday. The one on the door post is there but I believe there is another at some other location on the car. Thanks Larry
VIN # 1941 commander
The one on the door post is probably the only one you will find. The "secret" serial number stamped in the rear frame crossmember is probably long disappeared.
It's a little late now for Friday but, if you need additional documentation, and your '41 has not been molested, you can order the original factory production sheet from the Studebaker National Museum. It will include the engine number that was installed in your chassis.Brad Johnson,
'56 Sky Hawk in process
On the pre WWII models the serial number is stamped into the left underside frame rail directly below where you would enter the drivers door. It is not stamped very deep and much wire brushing will be required to bring it out. However it should not be necessary unless the inspector sees something amiss with the original serial plate.Richard Quinn
Engines can, and have been, easily changed. Most, if not all, states that require a title have adopted the body/chassis serial number for registration purposes; especially incitefull if there is a matching number stamped somewhere on the frame. If replacement titles are being produced, I would encourage use of the serial number.Brad Johnson,
