View Full Version : Rubberized fabric in engine compartment
vegas paul
06-07-2007, 10:14 PM
Within the engine compartment, attached to the inner fender (wheel well?) are pieces of rubberized fabric, presumably to keep road tar/dirt/etc. from entering the engine compartment. These appear to be "stapled" into the metal of the inner fender. If I want to replace these, what do I use and how do I attach them?
Las Vegas, NV
http://i151.photobucket.com/albums/s144/vegas_paul/1462673_2_350.jpg?t=1180041622 http://i151.photobucket.com/albums/s144/vegas_paul/graciestude.jpg?t=1180041703
gordr
06-07-2007, 10:52 PM
The factory used a big, heavy-duty stapler, near as I can tell. One that was tough enough to punch through body metal.
If "concours-perfect" is not an issue, pop rivets or small nuts and bolts would be appropriate. If concours-perfect IS an issue, then the only answer I can see is to form new staples out of soft iron "mechanic's wire" and use an awl to punch holes in the new flaps to lineup with the pre-existing holes in the metal.
FWIW, later model cars use plastic "Christmas Tree" fasteners for stuff like this.
vegas paul
06-07-2007, 10:53 PM
What do I use for replacement material? It looks like old tires cut up!
Las Vegas, NV
whacker
06-08-2007, 12:14 AM
I think you have answered your own question! I have also heard of people using pieces of conveyer belt.
60Lark
06-08-2007, 12:48 AM
I replaced mine with 1/8" black neoprene gasket material, purchased it from a local aftermarket gasket shop. This material is typically used on high temp.steam system applications.
http://im1.shutterfly.com/procserv/47b6ce20b3127cce8d0e3b50356c00000000400CcNWTlozYsb http://im1.shutterfly.com/procserv/47b6dc03b3127cce970d7aafd15f00000010100CcNWTlozYsb
Studebaker Fever
60 Lark
51 Champion
Phil
Arnold, Missouri
garyash
06-08-2007, 09:59 AM
You can cut some from a mud flap for a big truck. A jig saw or saber saw will cut through them. The mud flaps also make good material for body mounts and shims.
Dartmouth, Mass.
'48 M5
'65 Wagonaire Commander
'63 Wagonaire Standard
55studeman
06-08-2007, 12:26 PM
Not sure if it's available for a 51, but for 55' HT, SI has them available -bought some a few years ago.
Best Regards,
Eric West
"The Speedster Kid"
Sunny Northern California
Where the roads don't freeze over and the heat doesn't kill you.
And an open road is yours to have -only during non-commute rush hours 9am-4pm and 7pm to 7am (Ha, ha, ha)
55 Speedster "Lemon/Lime" (Beautiful)
55 President State Sedan (Rusty original, but runs great and reliable)
N8N
06-08-2007, 03:06 PM
I'd check with either SI or else FBN Upholstery, I know I've seen them at at least one of their displays at various shows.
vegas paul
06-08-2007, 04:00 PM
If I can cut them from available material, it seems like that's easier and cheaper than buying a specialized part. I still have my old ones(torn and frayed) to use as patterns. I'll get some mud flap material. Thanks.
Las Vegas, NV
lstude
06-08-2007, 09:12 PM
quote:I'll get some mud flap material. Thanks.
Make sure you don't get the ones with the mud flap girl on them. :D
Leonard Shepherd
http://leonardshepherd.com/
http://i129.photobucket.com/albums/p235/lstude1/Mein64DaytonaatBradfieldssm2.jpghttp://i129.photobucket.com/albums/p235/lstude1/52Commanderoutofgarage4-3.jpg
