I have a 1948 Land Cruiser. The coating on a lot of the wiring in the engine compartment and under the car is cracking and flaking off. That leaves me with a lot of bare wires. Have any of you installed a new wiring harness? If so, is it a job that the average guy can do? Joe
Wiring Harness
I put a wiring harness in an Avanti and it went well. I had the shop manual so I knew how to remove the dashboard. I used a NOS harness and followed the wiring diagram in the manual to get everything connected up right. I cautiously connected the battery and no smoke and it all worked. It was less work than I expected. Your results may vary. Go for it.
Ken
Joe,
If you get a generic harness be certain it is gauged for a 6-volt system. Several Stude vendors have the proper harness available in modern wire. If you want the original lacquered braided wire you will need to contact YnZ's Yesterdays Parts or Rhode Island Wire Service. Both make beautiful harnesses that will cost twice as much as Stude vendors supply.Brad Johnson,
'56 Sky Hawk in process
Yeah, an average guy can do it.
But best to know what a harness does and doesn't consist of. Studebakers West (who makes 'em) probably sells a main chassis harness, a body harness, and an overdrive harness. This will power your car, run your lights, etc. It does NOT include wiring for things like dome light, glovebox light, clock, radio, etc.KURTRUK
The Studebaker West harness's may not include the glove box light, radio, & clock, BUT, they are the correct colors and by following the wiring diagram in the shop manual, they pretty much fall into place! I've used one on my 52 Commander and most recently on my 63 Avanti.
Jim"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
