I decided to try and crank my motor over since everything checked out OK so far. I have an old deep cycle battery that still has most of a charge. Yes I know it is a 6V starter and my battery was a 12V but it was at about 10V now and we used to run 6V starters in bugs once we converted them to 12V all of the time.
I was not energizing the entire cars electrical system, just putting voltage right to the starter to get it to turn over. It didnt crank over or spin at first at all. After a few times of contacting the positive post it finally broke free and spun but too slow to throw out the bendix gear.
I thought maybe the battery was bad and just wouldn't turn it over. I pulled out the starter and cracked it open. It was full of crud like spider webs and bugs and just debris. Once I blew it all out it looked really good. The armature was a bit dirty but no rust. I used some 100 grit sand paper and scuffed up the armature, and the commutator even tho it looked good I just freshened it up a bit.
I took a fine wire brush and brushed up the brushes a bit just to knock off any old glaze. I looked inside and the magnets looked new with NO marks on them at all. There are obviously no bearings in the starter just bushings on the ends, I dont see thos being bad.
After blowing it all out and it looking new inside I put the armature back in and open the brushes so the arm/comm shaft drop in just fine. I put the nose cone on and everything looks great. I jump it to a good car and it still spins really slowly even tho it was connected to 12V battery.
What could go wrong?
