So as some of you know I am trying to systematically sort thru what pieces are ultimately useable and what are junk on my '52 2R10. The rear end seemed to check out very good and with some easy brake pieces the entire rear will be sound and good.
Friday I bagan an inspection of the transmission. Starting with draining the oil to see if there still is any oil, and then if there was also water or not and finally if there seemed to be any chunky, gritty, metalic, or rusty material in it.
All is well. Oil came out clean and smooth with NO scary stuff. The oil was dirty enough that I am sure it is old and used but clean enough to be confident that the innerds are good. It went thru the gears just fine and seemed to be in good order.
2 questions though just to verify some oddities. There is a solenoid looking unit on the drivers side of the trans pointing slight upward, maybe 30-40 degrees upward about 3/4 of the way back on the trans. It has 2 wires going to it. The module or solenoid or switch, whatever it is, is about 2-3 inches in diameter and 3-4 inches long. What is this?
Second question, in nuetral the drive shaft rotates freely in both directions. In reverse the drive shaft is solid feeling and other than the slight slop that is normal, will not turn at all, I believe that is perfect.
My head scratching moment is that when in 1st - 3rd gears the drive shaft is lock solid in one direction, but freely rotates the other way.....how is that possible, and is that normal?
Side note, the drive shaft also check out great. There is only the center u-joint that has ANY play at all and even that is useable feeling to me, at least for now and with a little greasing. This think seems to be really checking out well so far, Im getting excited that it could be driveable fairly quickly and affordably.
