So I've got the door panel off the passenger side door, but can't make head's or tails of the mechanism. I can barely get my big hand in there to feel around. It seems like the window is in the forward and rear tracks. I can push/pull the window up about 1/2 inch, but it refuses to go down at all. The window itself is about 1/2 way down. The window crank handle won't budge past about 1/8 of a turn at best. Any ideas on what to do next?
Stuck window 56 Hawk
Tags: None
You have a regulator for the window and also the door handle linkage to deal with. The body parts catalogue will show you a diagram of what you are dealing with. Some of those bolts may need some pursuasion. All channel felts, cat whiskers and rubbers are available, as well as regulators. S.I. has parts catalogue reprints, as do many SDC vendors.Dave Warren (Perry Mason by day, Perry Como by night)
Probably you knickers (felt in the channel runs) have come apart and gotten themselves in a bind.
Time to dis-assemble and replace worn channels.Brad Johnson,
'56 Sky Hawk in process
I've had good results by cleaning out the old worn material in the channels & glueing in velcro to replace the worn felt. Inside the door nobody would know the difference & on the vent window (Hawks dont use felt there unless its a coupe) who would look to see its velcro?59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
