62 Lark. I'm replacing bushings on control arms. One side went fine. On the passenger side I need to remove the tapered pin on the lower control arm threaded pin in order to fit the control arm back on. I didn't need to remove the taper pin to remove the control arm because the grease seals were gone and I was able to manuever it off. However I can't replace the control arm with new seals unless I remove the taper pin and drive the threaded pin over a 3/8 inch or so as I did on the other side. The problem is I can't remove it. I've tried heat and so far have bent one punch and am now starting to punch a hole in the top of the taper pin but it wont budge.
Any ideas? Am I going to be stuck drilling it out? I was making such great progress until this. Thanks.
