View Full Version : Engine: Aluminum Intake & Vaporlock
JoeHall
08-23-2011, 09:33 PM
A question for the fortunate few that have them, does the aluminum intake reduce or eliminate vapor lock?
Thanks,
Joe
DEEPNHOCK
08-23-2011, 09:59 PM
No.
If the aluminum intake has the heat crossover passage in it, it will be affected just like a cast iron intake will.
Adding a heat insulator carb base gasket helps a lot.
Now, if you block open the heat riser valve (or gut it, or remove it), and then block the crossover passage in the intake (stainless steel plate(s) with a composite intake gasket...
Then you can help the issue somewhat.
Adding an electric fuel pump helps a lot.
Adding a quart of diesel fuel to a tankfull of gas helps some.
Adding a fuel line bypass return helps the most, but is the most involved to set it up.
08-23-2011, 10:10 PM
Agree with all Jeff's comments above, except:
Adding a quart of diesel fuel to a tankfull of gas helps some.Jeff and I will have to agree to disagree on this one. Petroleum engineers have convinced me nothing good comes of putting diesel in gasoline.
jack vines
Mike Van Veghten
And an electric fuel pump eliminate it all together. Just pressurize the system.
Courious, how come, me, living in one of the hotter states in the US, have never had a vapor lock problem. Or am I overlooking something ?
And it isn't because I'm only 16 years old (almost 61)...!
My daily driver 259, Lark wagon does not have an electric fuel pump...
JoeHall
08-23-2011, 10:21 PM
I learned to deal with vaporlock over the years, and have applied most of the above suggestions; the collective sum of all of them helps quite a bit, but still does not eleminate it.
With the question above, I was just following up on a conversation I had with a guy in Springfield. He had an R something engine, and told of horrific vaporlock problems, but swore all went away with the installation of an aluminum intake.
DEEPNHOCK
08-23-2011, 10:41 PM
Well, I could have suggested clothespins:rolleyes:
I have added diesel during the hottest months in Florida, and it has always seemed to help.
I never cleared it with any engineers, as they never agree with anything I say anyways.:rolleyes:
(I can say the putting too much diesel in just makes your car stink like diesel fuel)
Jeff:cool:
Agree with all Jeff's comments above, except:Jeff and I will have to agree to disagree on this one. Petroleum engineers have convinced me nothing good comes of putting diesel in gasoline.
jack vines
JoeHall
08-23-2011, 11:02 PM
I think I willl give diesel a try. Nothin ventured-nothin gained. I have saw people with 15-20 clothes pins clamped strategically (from one end to the other of the gas line). Some said it helped, others weren't so sure.
Having a fuel return line allows one to drive away quicker, instead of waiting a couple minutes at high idle for solid gas to enter the line and fill the float bowl. But it will start hard. I had return lines on all Studes in teh California desert, and that was my experience. Problem is, when the in-line filter gets even a little dirty it will start returning so much fuel to the gas tank the engine will starve. Once in KY, as the filters got dirty, I just pluged the lines off. My cars from the desert still have the return line in place, but plugged off. They were not much trouble to install initially. I used copper line, and plumbed into a 1/8" pipe plug with 1/4" line fitting in the fuel filler spout, about six inches down from the cap.
Joe H
DEEPNHOCK
08-23-2011, 11:11 PM
Copper is a no-no for fuel lines.
Vibration can cause it to crack and leak...
<snip>
Joe H
JoeHall
08-23-2011, 11:20 PM
I know, but I spent a 30 year career living on the edge (Marine Corp) :)
