View Full Version : Brakes: remote resviour/ dual master/ Turner bracket
TXmark
08-23-2011, 01:39 AM
does any one have some positve experience with this setup.
the only master I found is a Wilwood with 30" total length of hose for both resvoir
the only master I found with the fittings on the outboard side was a Jeep master
my upgrade is over due, the master was leaking and one of the lines easy twisted off due to rust.
I'll probably do the disk brake conversion sometime soon
also a shot of brake fluid right in the eye does not hurt that bad:p
Pat Skelly
08-23-2011, 02:31 AM
Mark look over this page. This is what I did with my 62 Hawk, with Turner discs. http://www.studebaker-info.org/64v2488/eclipse/eclipseMC.html
junior
08-23-2011, 08:17 AM
Nissan Quest or Merc. Villager van from the mid 90's works well. Got the idea from Jerry F, works well for my 54 coupe with Turner discs on the front. Junior
woodysrods
08-26-2011, 11:15 PM
Thanks Junior
I knew you would come thru once again.
Are you about ready to bring that old Stude out to B.C.?
How about Radium on Sept. 17th??
Good Roads
Brian
