OK, the forum has helped me much by confirming that the pre-'56 6 volt systems typically originally used a flat braided steel ground battery cable. I'm thinking specifically of the '55 Speedster.
I realize that steel has far higher conductive resistance than copper. I've seen references to flat braided cable in 2 gauge and 0 gauge, but I can't find any information regarding the conductive qualities of 0 gauge round insulated stranded copper cable vs 0 gauge flat braided cable. Do the gauge measurements simply refer to physical dimensions? Or to conductivity?
Hot engine restarts are a little sluggish with the current (insulated copper) setup, don't want to make it worse by a switch to more "authentic" flat braided steel.
Thanks.
Thanks.
