View Full Version : Brakes: hill holder repair
dlp
08-21-2011, 02:19 AM
Does anyone know if there is a rebuild kit for the hillholders I would like to go though mine on a 48Champion
Welcome
08-21-2011, 07:11 AM
WELCOME ...to the SDC Forum!!!
Not sure which style you need as there were small differences over the years.
Studebaker International does offer Hill Holder Seal Kits.
Good Luck!!!
Stude-Dude
08-21-2011, 01:18 PM
the seal kit is all that mine needed...
found out the hard way though...
i "rebuilt" the Hill-Holder out of dad's '53 and put that on the '61...
no dice, so i now had the '61 Hill-Holder off the car and in hand, did the same "rebuild" on it and INCLUDED the seal kit this time - works now...
i know that the '53 and the '61 Hill-Holder are the same, don't know about the '48...
though i suspect it may be the same (truth be told, i didn't know the '48s had one, did you add it?)...
kurtruk
08-21-2011, 08:30 PM
Available starting in 1936, I believe.
dlp
08-21-2011, 10:26 PM
No it came on the car new
55 56 PREZ 4D
08-23-2011, 03:57 PM
I ordered the hillholder seal kit for my 56 Pres from S. I. The new copper seal for the end cap would not fit. I had to reuse the existing fiber seal. So far no leaks.
I understand that you can use EDR/EPDM o-rings or flat rings. [Brake fluid resistant. Regular rubber will dissolve.] Both are available online but I could not find anywhere that would sell just 1 or 2.
Bulk orders or min purchase only. Couldn't find anyone local that handled EDR/EPDM.
Make sure you orient the camshaft correctly when you reinstall it.
Paul Keller
08-23-2011, 07:28 PM
Dan,
How did you get the screw-on end screwed off?? Nearly broke the handle off a pipe wrench trying to remove mine.
regards, Paul k
55 56 PREZ 4D
08-24-2011, 11:20 AM
Paul:
See your private messages.
Dan
