I am working on the windshield washer system I noticed I have a electric switch under the dash. There is a wire going to a bracket. I know I need a washer bag but what type of electric pump do I need. Thank for help..
Avanti electric washer system
Tags: None
What year Avanti? Originally there was a foot operated pump located above the dimmer switch. There was no electric pump involved. There was also a switch mounted on the foot pump that activated the wipers (hands free)! Some later Studes have the same setup.
The foot pump is a rubber bellows that expells washer fluid when stepped on, and draws it in when "relaxed". The washer bag has a one way check valve built into the cap.
The larger hose goes to the foot pump, and the smaller hose goes to the nozzle in the cowl.Bez Auto Alchemy
Originally posted by jerry1 View PostI have a 1963 Avanti. There is a push button under the dash with wires going to the wiper bracket.
Most parts stores will stock a generic pumpBez Auto Alchemy
