View Full Version : Avanti Trivia Question
studegary
08-08-2011, 02:08 PM
What material was the major portion of Avanti bodies made of? Give response by year or year range.
Depending on the response, I thought that I would try trivia questions from time to time.
radiotech
08-08-2011, 02:16 PM
To the best of my knowledge it was fiberglass reinforced resin fro start to finish !!! ??? 62 to end of production 2006?
studegary
08-08-2011, 02:21 PM
Incorrect ----
stupak
08-08-2011, 02:27 PM
This is off the immediate subject BUT......rumors persist that a 'metal' Avanti was built, sometime early in the Studebaker production run. Anyone have further information? stupak
8E45E
08-08-2011, 02:31 PM
I'm not sure if you are looking for a chemical breakdown of the material an Avanti body is made of, but an essential component of fiberglass is Boron.
studegary
08-08-2011, 02:37 PM
I believe that prototype steel Avanti style prototype/design models were made, but my trivia refers to production models.
studegary
08-08-2011, 02:38 PM
No, I am not looking for the composition of Fiberglas.
Gunslinger
08-08-2011, 03:30 PM
I believe Steve Blake changed the material to a Kevlar composition that could be formed in larger pieces so there would be far fewer pieces that needed to be bonded together. That would save many man-hours of labor as the 100+ piece fiberglass bodies took hundreds of man-hours to assemble.
It was the Kevlar based bodies that had the problems of the new Deltron paint not adhering, which was a big part of the bankruptcy of Avanti Motors.
studegary
08-08-2011, 03:44 PM
You are on the correct track, but incorrect owner/time frame and not tied into the paint problem.
53k
08-08-2011, 03:59 PM
Fiberglass except for the '90 four-door sedans and the '91 convertibles which were kevlar.
bezhawk
08-08-2011, 05:20 PM
I believe they called it FRP (fiber glass reinforced plastic) The plastic being an epoxy binder.
8E45E
08-08-2011, 05:31 PM
One experimental Studebaker I sure hope to see restored someday is the 1947 Champion 2-door wagon with body panels and roof made of FRP. The threads in the woven mat were tinted and meant to be exposed behind a few mils of clear epoxy on the outside surface. Behind the matting was colored resin a different shade to contrast with the matting, which gave it a fine basket weave texture with some depth to it. How well the original body stood up while exposed to the weather is a good question, but it would still be nice to see it restored.
studegary
08-09-2011, 12:27 PM
Very Good, Paul J.! It took longer than I expected. I expected some Avanti expert, or good researcher, to jump right in with the answer. I will post another trivia question.
Avanti bodies:
1963-1985 Fiberglas
1987-1989 Fiberglas
1990-1991 Kevlar
2001-2007 Fiberglas
kurtruk
08-09-2011, 07:35 PM
Craig,
There were two '47 Champion wagons, right? The one the Museum is hopefully soon to be done restoring is not the one you refer to, correct? I am not aware of the one you refer to as having survived. Do you know otherwise? Not challenging you, just trying to clarify. Is it still in the Graveyard?
And anyone else that replies, please be aware that there were two '47 wagons. The one rescued from the Graveyard with no FRP is the one being restored by the Museum.
mbstude
08-09-2011, 08:20 PM
Craig,
That's right, Kurt. The Woody is the one the museum has been restoring for several years now. The 'glas wagon was hauled out of the Graveyard in the early 70's and as far as I know, hasn't been seen since.
studegary
08-10-2011, 01:42 PM
I thought that Max C. had/has it.
