overdrive questions 1960 6 cylinder (red) Lark
Simply throw the toggle switch while you accelerate to normal traffic speed. If the solenoid is working, it will shift to overdrive when you slack off the gas. Once in overdrive, it will stay there until the switch is turned off, even if you come to a stop and shift into reverse. That can be trouble, which is why the manufacturer went to all the trouble to provide a governor, relay, and kickdown switch.
Your governor should still be there, or else there will be something else plugging the rather large hole it occupied.Gord Richmond, within Weasel range of the Alberta Badlands
I drove my truck that way for several years before I took the trouble to find a governor. It works very well, you become the governor, but you have to remember to do your job. You can pull the OD handle out, locking out the OD and drive as a normal 3 speed. You can then push start and won't have freewheeling.Don Wilson, Centralia, WA
40 Champion 4 door*
50 Champion 2 door*
53 Commander K Auto*
53 Commander K overdrive*
55 President Speedster
62 GT 4Speed*
63 Avanti R1*
64 Champ 1/2 ton
* Formerly owned
