At some point in my Lark's past they put in a starter with a built in solenoid. I believe the solenoid is going bad. While infrequent so far, occasionally turning the key results in a faint click and nothing else. Wait a few and try again and it usually works, though today I had to jump the solenoid leads with a screwdriver to get anything to happen.
Battery appears good though the amp light always stays lit. (Battery is charged, alt looks new and seems good [will run with battery disconnected].)
The original solenoid is still bolted in place but I don't know it's condition. Does anyone know of problems in bypassing the built in solenoid and returning to it's original configuration? If I can't get the built in solenoid fixed I'd rather bypass it than have to replace the entire starter.
