WHere is the VIN number on a 55 truck. My title does not show the same number as on the serial number plate on hte drivers side door.
I have a 1955 E5-12 (1/2 ton), and the number that the state of California (where I bought it) calls the VIN is the engine number, stamped on the block at the upper left front, on the left side. There also is Studebaker's serial number, located on the plate on the drivers side, just below the seat.
[img=left]http://rocketdillo.com/studebaker/misc/images/Avacar-hcsdc.gif[/img=left]DilloCrafter
1955 1/2 Ton Pickup
The Red-Headed Amazon
Deep in the heart of Texas
Paul Simpson
"DilloCrafter"
1955 1/2 Ton Pickup
1955 1/2 Ton Pickup
Paul Simpson
"DilloCrafter"
1955 1/2 Ton Pickup
In the '50s, many/most states used the engine number, rather than the serial number for a VIN (vehicle identification number). If the number matches your engine number, you are in luck. If the engine has been changed, buy the build sheet from the Studebaker National Museum. The build sheet will show the correlation between the original engine number and the serial number.
1959 DeLuxe pickup (restomod)Gary L.
