It looks kind of like a rickshaw right now as everything has been stripped from the firewall forward except the frame rails. You can see in this picture that the steering column and gear shift lever has been cut off at the steering box. They will both be modified for use with the new powertrain. The frame has been cleaned of it's 62 years of the rust inhibiting coat of oil, grease, and road dirt. If you look closely you can see the new bracket for the dual master cylinder that is lying on the floor under the truck. Also, you may notice the clutch pedal is still there. With a 4L60E being installed, can anyone figure out why I am leaving the clutch pedal in? It will have a function other than just looks.
The new "heartbeat" that is being dressed to go back to work in a much more attractive environment.
