My car, a 54 Studebaker, has a B 383. The car is a very light car (2800 lbs from the factory) and insn't much heavier today. I am in search of a good street cam. Like all street machines I want something loud and with a wild idle. I also can't go too crazy as my car is a street machine. The engine a 1967 and is unrebuilt, but is in immaculate condition internally. The engine is one with a 9.2:1 compression ratio and I think it has the 516, closed chamber heads. The engine has a Wiend dual plane intake and Hooker fenderwells. I have a stock 72 727 I am about to put in and I have stock 3.23 gears and 26 inch tires. I want to make a cam descision now though I am not buying a cam for a llittle while so that I can make a torque convertor descision. How would the rpm stall affect street driving? I want a hydraulic cam and rollers are much too expensive. I have been looking at many cams and want to know what is best for my engine.
Here are a few I have looked into:
http://www.hughesengines.com/Index/p...z&partid=25115
I really like this cam, but have no I dea what stall to use. How is there so much duration and lift for a low compression engine?
http://www.compperformancegroupstore...=WDGCAMhydFTXE
http://www.compperformancegroupstore...DGCAMhydFTxeHL
this one may be a little too much
I really like this one
This is basically what I am looking at. I have no favorites. When I do get a cam I will get cam, lifters, springs, roller rockers, and if I am taking the heads off I may get a valve job and port my heads. What are you running? How does it perform? Do you have any other recommendations?
I also posted this on a MoPar forum, but want to know what yall think.
