Intake Ports
Those port sizes are from a Dick Datson publication. The smaller ports shown are the standard size ports from 55-64. The larger ports on the right is an R3-R4 size manifold and is extremely rare, and will in no way ever fit non R3 heads.Bez Auto Alchemy
mostly interested in the 232 ci intake
jack vinesPackardV8
Let's narrow it down for you.
If you have the original heads on an early V8 (232), the ports are smaller than they are on later models.
The clamping down method is a little bit different, too.
The coice of intake manifolds is easy.
You have the stock 2bbl intake (takes a 2bbl 'side inlet' downdraft carb).
You could rebuild your carb and keep going...
Or....
You could swap a later style 2bbl downdraft carb and intake with a stock air cleaner...
(You'll need the later style mount clamps and bolts)
Or...
You can search out and try to find an old Offenhauser aluminum 4 barrell intake.
That also has the smaller port runners.
But it also has a carb base flange that is real small, and finding a good carb for that manifold will be hard...and expensive.
And on top of that, you will have to find the matching Offenhauser air hat to hook up to your air filter so the hood will clear everything.
An adapter for the Offy intake can be made, but hood clearance is going to be something to keep in mind.
Thin Avanti motor mounts can help, but then you also have to pay attention to driveline alignment and fan to shroud clearance.
Or....
Just put a later model 4bbl intake on
Either a WCFB intake and carb, or an AFB converted 2bbl intake, and AFB modified WCFB 4 bbl intake, or a late model AFB intake...
All the latter will require the later mounting clamps and bolts (no big deal),
and an aftermarket 'thin' air cleaner (for hood clearance).
Yes, you will have some port size differences, and ultimate performance might be slightly affected...
But overall performance will be better...if...If you put a small, small, small 4bbl carb on there.
Easy to over carb that engine.
HTIH (Hope the info helps)
Originally posted by Alexander Feiman View PostI guess that main reason is I'd like to buy an intake for a 232 and not another size because the runner ports vary in size. I see intakes for sale but usualy don't state year or engine that they were removed from and I would like to know a way of identifying them.HTIH (Hope The Info Helps)
One way of telling, is that the 232 intakes don't have the 4 end holes (1on each corner). They clamped down with just four center bolts and long clamps. If you did change to a later manifold, you would have to drill and tap the heads for the end holes.Last edited by bezhawk; 07-12-2011, 01:44 PM.Bez Auto Alchemy
Send me a note and I'll share some idea's with you...
Originally posted by Alexander Feiman View PostLOOKS GREAT but I'm just playing aroud with what I have and just wanted to trying to machine my own intake.HTIH (Hope The Info Helps)
There are four different part numbers for the small-port 1951-54 V8 intakes. Some of these were machined from the same casting. I don't know how many different castings were used for those years. The only one I have in my file is 154731. I think the casting numbers were on the bottom of the early manifolds.Restorations by Skip Towne
There must be something wrong with that casting number, a 232 is too old for a "15" Part/Casting Number, and all others start with a "5" and have 6 Digits.StudeRich
