During reassembly of my R1 engine I noticed it had studs on the #4 main cap bolt heads. Looked like they should be for a windage tray? This engine didn't have one! Was it supposed to? If so where can a aquire one? Also is there are torque spec. for the two 5/16" oil pump mounting bolts or just tight? Thanks. Bruce.
Windage tray
Yes there should be a baffle that bolts on there and the pan should have a tray welded in. Phil Harris at Fairborn Studebaker is your friend on this. 937/878-1576Jim
Here's one source.....
And a pic..
Originally posted by MCCAB1 View PostDuring reassembly of my R1 engine I noticed it had studs on the #4 main cap bolt heads. Looked like they should be for a windage tray? This engine didn't have one! Was it supposed to? If so where can a aquire one? Also is there are torque spec. for the two 5/16" oil pump mounting bolts or just tight? Thanks. Bruce.HTIH (Hope The Info Helps)
