View Full Version : Rocker arms clattering again
MagikDraggin
05-26-2007, 12:48 PM
Is it 'normal' for the valves to go out of adjustment in only a few hundred miles?
I adjusted them not that long ago, and now 2 or 3 were really starting to clatter rather loudly after driving for awhile and getting the motor up to temp......they are nice and quiet at start up, though.
So I pulled the valve cover on the passenger side (motor still nice and hot) and found #2 & #8 to have nearly .032 valve lash. I brought them back to .025 and buttoned it up...now, it's reasonably quiet again.
Am I doing something wrong here or possibly missing a step? The half-inch adjusting nut(s) are self-locking aren't they?....that is, there isn't some way of actually "locking" them in position?
http://img.photobucket.com/albums/v147/MagikDraggin/Other%20Stuff/IM000986-reduced.jpg?
1962 GT Hawk 4sp
JDP
05-26-2007, 01:04 PM
The nuts sometimes will lose their interference fit and work loose. They should be very hard to turn unless they are worn out.
JDP/Maryland
63 GT R2
63 Avanti R1
63 Daytona convert
63 Lark 2 door
62 Lark 2 door
60 Lark HT-60Hawk
59 3E truck
58 Starlight
52 & 53 Starliner
51 Commander
KOOL R2
05-26-2007, 02:14 PM
I have a similar problem. Has anybody tried "red" loctite on these?
Karl
05-26-2007, 03:30 PM
If I were to use the Loctite . It would be the Blue. The Red is just what it says. A thread locker, will need heat to break loose.Like JDP said they should be hars to move. May need to replace them.
63 Twin Supercharged Avanti
64 Avanti R3w/NOS
88LSC Avanti 350 Supercharged w/NOS
MagikDraggin
05-26-2007, 06:06 PM
64 Avanti R3w/NOS
Oh, no no no...no Loctite...I wanna be able to take it apart when/if the time were ever to come. Besides I'm not all that crazy about introducing a foreign substance (which hardens) into the path the oil takes.
So, to save me the time in researching this matter of replacing the worn locknuts, I presume all I have to do is undo the rocker-arm shaft assy? Any particular words of wisdom in regards to this sort of venture?
Thanks in advance,
Karl
1962 GT Hawk 4sp
