I will be pulling the engine and trans together (6 cylinder and Flightomatic). I have the entire front clip off the car and everything ready to go. My question is about the steering linkage in the center of the frame. The shop manual says to remove tie rods and turn it out of the way. It doesn't look like it will be a problem for me with the clip off and the ability to lower the trans at the rear to raise the front of the engine. It only looks like it would be a problem if i wanted to remove the engine only as you would have to slide the engine forward where it would get in the way. Can I leave the steering intact when I pull the engine and trans as a unit? Thanks.
Pulling Engine/trans out of Lark this weekend.
