For my Indy car replica project, I want to have the car running with 12 volt electricals - if only to be able to charge a cell phone. I'm using a 1937 President 8 engine that had 6 volt positive ground. The generator that came with the engine had been in the mud for a while, so I couldn't even turn the shaft when I got it. I cleaned out as much crud as I could, got it to turn, and oiled the bearings. These generators have a rear extension for the shaft that drives the water pump, which is mounted on the side of the engine, so I couldn't just grab any old 12V generator and use it.
Luna Industries in Tuscson, AZ (www.lunaindustriesinc.com) took the old unit, rewound the armature and replaced the coils, converting it to 12 volts negative ground. I'm still a long way from getting an engine to run, but I am happy with the conversion job.
Here's the generator after I cleaned it up a bit:
Here's the generator after the conversion:
