View Full Version : 1965 Cruiser tranny
JRoberts
05-24-2007, 09:43 PM
My '65 Cruiser is a V-8 w/automatic car. I have a couple of questions:
1. What automatic tranny came in that year Studebaker?
2. How difficult is it to put a late model GM overdrive automatic in the car and which tranny would you suggest? (I will be using the original engine with a few minor modifications.)
Thanks for the help,
05-24-2007, 10:17 PM
I believe they were all HD (water cooled) Flight-O-Matics behind the Chevy V8...the same trany that was standard with the Jet Thrust 63-64 Studes.
You'd need a new flex plate and torque converter, fabricate a trans crossmember and mount, shift and kickdown linkage and driveshaft. I don't know about clearance with the tunnel and floorboard.
Both the TH700R4 and TH2004R would work fine. The 200 is a little smaller package and not as deep a low gear.
V8's came with both 27 and 44 axles...flanged and keyed. If you have a 44 flanged you're golden...if not, consider an axle swap as well if you are going to have any extra HP.
Swifster
05-24-2007, 11:38 PM
The 700R4 was replaced by the 4L60 which should work as well. Newer GM's used the electronically shifted 4L60E which would also work with a harness and a controller if you're electronically gifted ;).
Tom - Valrico, FL
1964 Studebaker Daytona
http://i74.photobucket.com/albums/i280/Swifster/1965_Studebaker_Commander_front198x.jpg
05-25-2007, 09:19 PM
They weren't HD, Dick.HD may have been an option, butthey weren't standard.
I've got a couple of standard V8 auto trannys from 65-66 cars here if someone needs one.
Miscreant adrift in
the BerStuda Triangle
StudeDave57
05-25-2007, 11:49 PM
quote: They weren't HD, Dick. HD may have been an option, but they weren't standard.
When I first got Sweet Pea she did indeed have a radiator with the line in the bottom tank for cooling, but someone early on added a trans cooler, instead!!! Dad has that original radiator somewhere... I HOPE!!! ;)
My production order doesn't mention being ordered with a 'H/D' unit, nor was the car 'messed with' prior to my purchasing it back in '91- It's GOT to be a heavy-duty unit, because she's not had an easy life~ and is still going- 200,000 miles later!!!! [:0] [^]
Bob- just put one of those things in the trunk, and we'll discuss it later... ;)
StudeDave [8D]
V/P San Diego County SDC
San Diego, Ca
'54 Commander 4dr 'Ruby'
'57 Commander 2dr 'Baby'
'57 Champion 2dr 'Jewel'
'58 Packard sedan 'Cleo'
'65 Cruiser 'Sweet Pea'
