What is this guy saying???????
I can look at it in about a half hour drive, might go look any way.
I'd come across one such modification back when and was similarly gobsmacked by the sight. So there are at least two guys who always felt the Avanti needed a proper grille opening up front.
Come to think of it, didn't Raymond Loewy add some abomination V-trim to the front of his Avanti?
jack vinesLast edited by PackardV8; 06-13-2011, 07:27 AM.PackardV8
When you start a custom project, you should be prepared to finish it yourself... because few others will share your vision.
Didja see, "This ad is under construction"? That's the description. He'd better hurry and finish. I can't hold my laughs much longer.
Heck, I think those round air inlets on the front fenders are neat-o. They allow the air to cool the brakes and that chrome thing behind the wheels allows all the brake dust out. Good planning! AND that big hole in the front where he forgot to put a grille means rocks won't chip paint that ain't there.
JP, is this a cheap Avanti?
John
Customizing is customizing! The idea behind it is to create something that no one else has.
That said.....this guy had is own vision on how he would like his Avanti to look??? And the balls to try it.
My wife doesn't like Avantis because she thinks they needed a grill. Just her opinion because she is used to seeing cars with grills.
She would probably like this mans vision.
It is "ALL" good when you get pleasure out of what you are doing.
Good Roads
BrianBrian Woods
woodysrods@shaw.ca
1946 M Series (Shop Truck)
Skip the stuff on the sides...
The grille opening 'almost' has a good look to it....
Loved the $12 worth of rattlecan primer and the hour of hand sanding done to it.
Wonder how much Bondo is smeared on there?HTIH (Hope The Info Helps)
Well, the grill opening doesn't look too bad but final results would depend a lot on what sort of "mesh" gets put in it... The weird air intakes on the front fenders are not all that attactive IMO. The rear one in front of the rear wheel is sorta OK tho...
I think the mods look better with black/grey primer as-is and putting shiney paint on it would not be a good thing. Gives it a bit 'o mad-max look.
JMHO...
Jeff in ND
As long as I live, I will never understand why someone would take a beautiful car like the Avanti and butcher it.
Boggles the mind.
Rog'59 Lark VI Regal Hardtop
Smithtown,NY
