Are there any external markings on the axle that identify it as a Twin Trac? Thanks
How to identify Twin Trac axle
Tags: None
Pull the fill plug out.
Stick your finger in the hole.
If it goes all the way in, it is NOT a TT.
If it goes in only to the first knuckle, it is a TT.
Originally posted by Dougie View PostAre there any external markings on the axle that identify it as a Twin Trac? ThanksHTIH (Hope The Info Helps)
Or, jack up the car under the pumpkin enough to raise tires off the ground. Put car in neutral. Rotate tire and wheel assembly forward. If other wheel{not the front one} goes in the same direction at the same time. Yi Haa! Ya got a TT. jimmijimsigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
