View Full Version : 4L60 in Super Hawk
satdoc2
06-04-2011, 09:35 PM
Would it lower the value of a 63 Full package GT Hawk to replace the Power Shift with a 4L60 transmission while I have the motor & transmission out?
Allen
Milaca
06-04-2011, 10:10 PM
As for me, it would be ideal to have it with the overdrive transmission as I like to drive my Studebaker on the highway at highway speeds (65 mph or more) and not have the engine screaming from running at high RPM's, plus gaining fuel mileage would be appreciated. But, for those that trailer and show their cars, it would probably be more valuable to them to retain all things original. Perhaps the car could be returned to original if a future owner wished to make it that way?
DEEPNHOCK
06-04-2011, 10:46 PM
If you ever intend to sell the car to a purist...Yes..It will reduce the value.
Allen
royvaldez
06-05-2011, 07:03 AM
Go for it. I am planning put one in my car.
okc63avanti
06-05-2011, 07:40 AM
If your GT is already a 1st place winner at meets maybe Jeff is correct, but if its an older original or an older restoration then the value should you ever sell it probably will not be affected too much. There are lots of people selling their Power Shift trannies as many choose to replace them with GM 4speed automatics, so their are many available to put back into if someone wants originality, or you can just hang on to yours to sell with the car in the future.
jimmijim8
06-05-2011, 08:39 AM
As for me, it would be ideal to have it with the overdrive transmission as I like to drive my Studebaker on the highway at highway speeds (65 mph or more) and not have the engine screaming from running at high RPM's, plus gaining fuel mileage would be appreciated. But, for those that trailer and show their cars, it would probably be more valuable to them to retain all things original. Perhaps the car could be returned to original if a future owner wished to make it that way? Easy on the engine is the way to go. I try to keep the RPM's 2100 max with FOM 3:31 but then again I don't mind just driving a bit under 60. If you change to an overdrive, retain all parts for reasons previously stated. Oh yea. . jimmijim
Pat Dilling
06-05-2011, 09:35 AM
I agree that an overdrive automatic is the way to go. I suggest though that you consider a 200-4R rather than the 4L60. They are a more compact transmission and the gear ratio spread is much better. The 4L60 is essentially a 700R4, it has a very low 1st gear 3.06 and has a big drop to a 1.63 second gear. The 200-4R has a 2.74 1st and 1.57 second. They both have similar OD ratios, .7 and .67. Your motor needs to have a strong, flat torque curve to overcome the big RPM drop on the 1-2 shift in the 4L60. It's like the difference between a wide ratio and close ratio in a 4 speed manual.
As for originality, just keep the original trans, cross member and drive shaft to sell with the car if it ever comes to that.
Pat
GEEMAC
06-05-2011, 10:26 AM
Installed a 700r4 in my 73 Avanti whitch has a small block 400 with a 4speed, replaced the 4speed with the 4l60 six yrs ago ,still have the 3.73 rear end, was thimking about going to a higher rear gear but preforms real well the way it is,made a lot better driver especially while driving the hills of south MO. an the Branson area. MAC
Corvanti
06-05-2011, 11:12 AM
agree with the 200-4R, unless you already have the 4L60 laying around somewhere. :)
Ditto on keeping the old trans, etc. for the same reasons...
TDITS
06-05-2011, 12:28 PM
Doesn't the 4L60 require a computer to handle shifting? I'm going with a 200-4r in my truck for reasons stated above. They aren't as popular or easy to find as the 700-r4 but they are out there.
Pat Dilling
06-05-2011, 08:09 PM
The 4L60 works like a 700R4, the 4L60E is electronic controlled.
Pat
