Any photos here on bolt through floor attachment areas for rear seatbelts for a C-= K model? thanks jimmijim
63 gt Hawk rear seat belt location.
sigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** memberTags: None
If you pull the lower rear seat cushion out, you'll find the factory installed "nut-plates" already there with a rubber plug in each one, provided it hasn't rotted away.
You might not see them at first because they're just above the area where the upper and lower cushion come together. The outside ones are actually mounted in the "wheel-house"...you'll see them. Hope this helps.
Dan Miller
Auburn, GA
Good to know this but I didn't notice this on a 63 I restored. Maybe it was an early 63
thankssigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
They started putting seat belt anchors in before 1962 as my 62 GT has them.
Originally posted by jimmijim8 View PostGood to know this but I didn't notice this on a 63 I restored. Maybe it was an early 63
thanksFrank van Doorn
Omaha, Ne.
1962 GT Hawk 289 4 speed
Originally posted by 41 Frank View PostThey started putting seat belt anchors in before 1962 as my 62 GT has them.sigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
