anybody know of a underhood, close-up photo showing the connections to a 58' - 63' OD switch (2-red, 2 black wires). 3-wire governor.....wiring diagram is a bit confusing...
OD kickdown switch wiring help
Tags: None
The kickdown switch, actually contains two 'switches' one is normally closed, I think that's the one away from the activation pin. You can check this with a test light, the other one, the two terminals back from the end, is normally open. when you push the pin, they reverse. The normally closed one interrupts the current to the coil/distributor. The other one is powered, and when closed energizes the solenoid. No, I don't know which terminal. I'ts been a while but I think black is the coil/distributor wire and red power for the solenoid.
In any case, red goes to red, black to black. Unplug all of them and check the switch action before continuing.
where the wires go
looking at Dwain's posted picture, with the plunger pointing toward you, the wiring hooks up on my '63 Lark as follows:
black to # 6 on solenoid - ////////// - red hot lead
---------- left side ----- ////////// --- right or fuseside ---
red to # 8 on solenoid - ////////// - black to dist./ coil
----------------------- plunger -------------------------
HTH, Bishsigpic"Somewhere West of Newport Center"
1956 2E12 O/D SOLD!
1959 4E2 4spd, TT
1963 8E28 GSA order
1963 8E5 SOLD!
1963 Lark Daytona Wagonaire 289,O/D, TT
