53 6 cyl pickup. Have 7+ volts to coil; coil tests fine; no spark thru points; no spark at plugs or primary of coil. Coil is geting hot. R211 so no resister that I can tell. Distributer is rebuilt. Any ideas?
Starting problem
If the coil is hot enough so you can't keep your hand on it... It's bad.
Originally posted by rpwhiteaker View Post53 6 cyl pickup. Have 7+ volts to coil; coil tests fine; no spark thru points; no spark at plugs or primary of coil. Coil is geting hot. R211 so no resister that I can tell. Distributer is rebuilt. Any ideas?HTIH (Hope The Info Helps)
