The speedometer on my 57 silver hawk does not work. I disconnected the cable from the transmission and the gear is on the end and it looks good. I spun the gear but no response from the speedometer pointer. I disconnected the cable from the speedometer and found the end was rounded off.
I then bought a universal core kit and installed it. When I spin the gear on the end, the pointer jumps. However, when installed, the speedometer still does not work. The pointer does not even jump.
I stuck my finger in the cable hole of the transmission and could feel what felt like a "worm" gear on the front side. Is that what it should feel like? Is there something inside the transmission that could be broken?
I am wondering if I made the core too short. I cut the core so that the gear was sitting flush against the cable housing. If the gear should be sticking out some distance and not pushed up against the cable housing then the gear is not going into the transmission far enough to mesh with the "worm" gear. Any ideas as to what my problem is will be appreciated. Thanks
