I have an Edelbrock 500 cfm carb with aftermarket linkage, which is very similar
to the stock linkage. I have no kickdown (downshift) at speed and according to the
manual, that's a carb linkage problem. As you can see, I have a spacer installed to
set the linkage out (away) from the carb, to try to get the right geometry. I have
the return springs installed per manual, and the linkage in the correct hole on the bellcrank. Any thoughts?
Joe D.
Joe D.
