I have a 1963 Cruiser R-1 that I may need a steering control valve. What years and models will interchange. Is the Avanti valve the same?
Contol Valve
Originally posted by gmax336 View PostI have a 1963 Cruiser R-1 that I may need a steering control valve. What years and models will interchange. Is the Avanti valve the same?
Allen1964 GT Hawk
PSMCDR 2014
PSMCDR 2013
Victoria, Canada
To answer the original question, control valves from all 61-64 Lark types will interchange. Part number 1551363. Be aware that they all look alike, and they all rebuild the same way, but there are differences between your control valve and those used on earlier models and on C/K models.Skip Lackie
Originally posted by Skip Lackie View PostTo answer the original question, control valves from all 61-64 Lark types will interchange.
Tom'63 Avanti R1, '03 Mustang Cobra 13" front disc/98 GT rear brakes, 03 Cobra 17" wheels, GM alt, 97 Z28 leather seats, TKO 5-spd, Ported heads w/SST full flow valves.
First off the Avanti valve is not 100% unique..........the only difference is the inlet port size.........indeed years ago my dad needed a valve for his Avanti and they were NLA...........not to worry...........Mr. God himself, Dave Spilski provided a different valve, just had to obtain port inserts from a trans shop.......then good to go!
Also I know many claim the valves can be rebuilt........but what do you consider rebuilt? Spool Valve seals?? Yes this will ameliorate a generalized leak........but what about if the inside diameter of the valve had been increased over the years? Spool valves do not come oversize like piston rings........and the process of spraying liquefied metal in that valve, then cutting down is completely out of the question financially.
My uncle was a machinist and metallurgical engineer, retiring in the early 70's.........that is how my dad and consequently I found out all the 'dope' concerning control valves..............FoMoCo gear heads suffer the same problems with some of the FoMoCo line of cars from back in the day.
- Likes 1
Originally posted by Skip Lackie View PostI knew someone would ask that question and I should've gone ahead and looked up those part numbers, too. The 65-66 Lark types use the same control valve (1551363) as the the 61-64 Larks. The Avanti control valve is unique and will not interchange with any other models.
I rebuilt the control valve in my wife's grandfathers 64 Ford Fairlane...........luckily it had spent over twenty years in dry storage and had so many leaks that there was not corrosion in the valve A word to the wise, be sure to polish the seal surfaces before reassembly. I didn't and was able to repeat the process There are some YouTube videos on doing it, which helps understand the process and some discuss the issues on corrosion and where it can be a problem. I have a small lathe and chucked the spool valve in the lathe (carefully) and used 2000 grit paper and oil followed by a polish with cloth and polish, the second time was successful. The cost for the kit was very low....even for two of them
