Figured most likely a bad gauge. Because there are so many threads about gas gauge, I've tried to search old posts. I don't find if there is a way to test a SW 6 volt gas gauge, out of the car? I get about 42 Ohms but don't know what to expect.
The sender in 1952 is apparently 0-100 ohms. I'd like to test this also, can you do it at the gauge end of the sender wire when it's not on the gauge? There is some gas in the tank, so if check between that and ground should I see some resistance between 0 and 100? I get nothing.
